Newest and smallest handling storage machine
I want to know about the new incoming items of storage of data which are light and easy to handle. I have to store a lot of data so I need help.
If you're hunt for a mighty, space-saving individualized computer that's small sufficiency to fit in the touch of your jack then the new LPC-100 from Stealth strength just sew all the appropriate boxes. In spite of its Lilliputian size the slight computer is claimed to do better than most screens and nomadic computers free today.
So check this one it must attract you, New LPC-100 mini machine from Stealth,
4.0 x 6.1 x 1.45-inch tiny PC has involved 3D-ready graphics to together VGA and DVI ports, with identification up to 2048 x 1536 for VGA and 1680 x 1050 for DVI.
Check its configuration in a glance.
1. Processor, 2.53 GHz.
2. Hard disk Drive, 500 GB.
3. Memory, 4 GB,
This is all something which is almost fit in palm.
Dear Anam277,
The storage device is important for data storage. Day by day storage device are becoming smaller with the advance of technology. As far I know IBM created the world most World's Smallest Storage Device. The size of this storage device is only 12 Atoms. In near future Gen memory chips and disk drives will be developed that will use less power and have larger capacities.
Thanks and Regards
Louis
