Newly installed software does not work
Hello experts
I have deleted the earlier installed software and then installed a new software edition.
But it doesn't solve the problem.
I have got the following error message shown in the picture, when I try to start the software.
Need a solution. Please help.
Thanks in advance.
Error:
ADF4150-USB ERROR
ERROR 1001-NO DEVICES FOUND
Best Answer by Robert B Guy
Answered By 0 points N/A #136651
This type of error is some time caused by the machine or probably by the windows updates.
if you have already installed net frame work(any version) remove it first than install net
frame work .Net 3.5 or .Net 4.0 from the below links:
.Net 3.5  http://www.microsoft.com/en-us/download/details.aspx?id=21 (if this is not working
install 4.0 version)
after installation restart your computer than run your desired software.Hope fully it will
work.
nauman
Answered By 40 points N/A #136652
Hi dear Ma McKinney,
Thank you for your question. The main possible cause is missing of Microsoft.net installer as well as the other main reason behind this is incompatible software.
Please follow the solution which is given below-
First uninstall the software. Then download CClearner and clean all the things by this software.
After that download the following software Microsoft.
At the last stage, install your desired software and make sure you download the right software.
Hope you like my answer.
