Not sure what happened but my PC crashed the other night so I had to re-boot. Since this has happened I haven’t been able to use Newsleecher and the following three Errors keep appearing. I’ve tried to uninstall and the reinstall the software but the same Errors keep appearing. Can anyone help me please to fix this Error ?
Thank you experts !
An application bug has occurred. Please help us improve the quality of the software, by checking the “Allow Anonymous Bug Reporting to Developer” checkbox, below. Thanks in advance.
Bug Data #1:
K2n2n
Bug Data #2:
Access violation at address 008AF66A in module ‘newsLeecher.exe’.
Read of address 0000000
Copy to Clipboard
Close
News Leecher an Application Bug has Occurred
See if it is only a random error. Restart your computer, start NewsLeecher, and check if a similar error will appear. If the problem is still present, try reinstalling the application again though you already reinstalled it. Uninstall NewsLeecher then click Start, All Programs, Accessories, System Tools, and then Disk Cleanup. Select drive C and then click OK.
Check “Temporary files” and “Setup log”, click OK, and then Delete Files. Restart the computer then install the application back. See if it works. If it doesn’t, try running the application as administrator. Right-click on the application’s shortcut then select Properties. Select Compatibility tab then check “Run this program as an administrator” and then click OK.
Start the application again and see if it works. If the problem continues, try updating the program to the latest version. Download NewsLeecher 5.0 Final.
