Hi Friends,
I need to have a PC application named newz crawler 1 9 that will work in Windows XP, Which is used to gathers news content from different channels which indeed is displayed.
Please do the needful for providing a download link towards it or suggest an alternative application.
Thanks and Regards,
Scott Athers
Newz Crawler 1 9 for Windows XP
Hello Scott Athers
The easiest way to download a software safe, usually it is to access the manufacturer's website.
The information provided there are the safest and cleanest, wrote in a easy-to-understand way.
So, I will present you with the link to download NewzCrawler 1.9.0 which is the latest version released.
As similar software's, I recommend to you SharpReader and The new way to communicate
I hope you will find this information useful.
Randolph
