zack lee
10 points
Posted on - 09/09/2013
Hi All,
I need to know more about Next Generation Firewall Open Source web application, that will help to defend web sites from attack. Please do the needful for providing details on this regard.
Thanks,
Zack Lee
Hello Zack Lee,
Next Generation Firewalls are developed for organizations that needs to create application at a higher level. Here are six features about Next Generation Firewalls:
1. The new technology will give you the opportunity to protect your stuff in a passive and real-time way from any attacks;
2. There is an Advanced Thread Protection too that works very well;
3. As well, you have control of the Thread Protection so you can prevent any damage that may be caused;
4. You can set up some the administration for automatic working. This means you will be protected and you won't have to do nothing.
5. You may think that your network performance will get lower, but it won't. The Next Generation Firewalls are designed to use a very low part of the computer's resources.
6. The best feature is the malware detection and blocking. This is the ultimate feature and it will protect you from many dangerous activities out there.
Hope it was helpful. Take care!
