Nextny org 443 uses an invalid security certificate
I am getting the following error message whenever I go to Tools -> Add-ons. I searched for the solution from forums but the add-ons were unsupported. What can I do to resolve this issue? I also installed the Webmail Notifier add-on but still not working. Is there settings problem in a browser configuration. I need an expert’s advice so please help me. Thanks.
Nextny.org:443 uses an invalid security certificate.
The certificate is only valid for *.pbwiki.com
(Error code: sel_error_bad_cert_domain)
This could be a problem with the server’s configuration Or it could be someone trying to impersonate the server.
If you have connected to this server successfully in the past the error may be temporary and you can try again later.
