Hello All,
How does nfo file generator for tv shows works with XBMC, where will it gets saved, is it possible to view the nfo files in any other video viewers, or do I need to use a convertor, so that it gets supported in normal video viewers.
Please do the needful for giving me the working and settings of XBMC,
Fred A Groves
NFO file generator for TV shows
Hi Fred,
The working and setting of XBMC are as mentioned below:
1) The main screen of XBMC is as shown below:
2) You can check for the weather for the specific city by clicking 'Settings' tab, select 'location setup', Click 'OK'
3) Rename the TV episodes and movies in XBMC is possible through 'FileBot' option. It will scan and ask the user to confirm the files to be renamed
4) You can install Add-ons by clicking 'Settings', select 'Add-ons', the list will be displayed. Select the one useful for you
5) Themes can be added by the user from the skins available in XBMC. Go to 'Settings' tab, select 'Choose Widget' tab and the style will be applied
