NI-DAQ Mx Driver Installation on Computer Error
Hello!
I have the NI-DAQ mx driver installed on my computer and I always get this error code 200324 in every installation.
I am using Windows XP Operating System for my computer.
Do I have to rest the driver to the previous version: NI-DAQ?
What do you think is the best solution for this error?
I will wait for your best suggestions.
Thanks!
Answered By 590495 points N/A #156375
If you have already used this driver before and this is the first time the error happened after upgrading it, try doing another clean installation of the driver again. Uninstall the driver then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like PC Tools Performance Toolkit, Norton SystemWorks, or Norton Utilities. There is probably an error in your hard drive’s file system that is affecting the function of the driver. Using any of these tools will help fix the problem.
If the driver still doesn’t work, try downloading it again. Or, if you are using an older version of the driver, try installing the latest version, NI-DAQmx 9.5.1. This version was only released last April 2012. To download this latest release, visit Downloads :: Data Acquisition This version supports Windows Server 2003 R2 32-bit, Windows Server 2008 R2 64-bit, Windows XP 32-bit, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit.
