NI-DAQmx Error-200452 Specified property is not supported by the device
I used Certain DAQmx Properties With My DAQ Board but I got a "Error-200452". What is the reason for this?
Primary Software: LabVIEW Development Systems>>LabVIEW Full Development System
Primary Software Version: 7.1
Primary Software Fixed Version: N/A
Secondary Software: Driver Software>>NI-DAQmx, LabVIEW Development Systems>>LabVIEW Professional Development System, LabWindows/CVI Development Systems>>Full Development System
Hardware: Multifunction DAQ (MIO)>>E Series>>PCI-6040E (PCI-MIO-16E-4), Multifunction DAQ (MIO)>>M Series>>PCI-6251
Here is my problem.
I tried to configure various properties using different DAQmx property nodes and I got Error 200452.
Snapshot has attached below.
Error -200452: Specified property is not supported by the device or is not applicable to the task.
Please help me to solve this.
Thank you.
Error – 200452 occurred at Property Node DAQmx Channel (arg 1) in Untitled 2
Possible reason(s):
Property: AO.IdleOutputBehavior
Channel Name: VoltageOut
Task Name: _unnamedTask<2>
