NI developer suite 2011 Installation Problem
90 points
Posted on - 07/11/2012
This message is displayed when I was trying to install software with MAX version 4.7.7 F 0.
I even re-installed it about ten times, but the NI developer suite 2011 still had this problem.
I need quick help to deal with this problem.
Thank you very much.
Measurement & Automation Explorer
SR-03-000-CPU (10.5.2.123): The selected system does not support this function.
