NI-FBUS Process Startup: Fatal Error
Hello!
Currently I have installed NI-FBUS COMM SW and PCI-FBUS card into my Windows XP which is for Windows v3.2.1. When I tried opening NI-FBUS Communication Manager, I received an error message which is:
“NI-FBUS Process Startup: Fatal Error
Initialize request for Board 0 timed out, NI-FBUS may not be receiving interrupts from the board. Check your board IRQ settings with the NI-FBUS interface configuration utility. NI-FBUS will not Exit."
I checked the settings and then set everything to default. The H1 interface board properties were then set to “Polled Mode” and I noticed that the NI-FBUS Communication Manager is successfully running.
I need your support and help. Thank you very much.
