NI-FBUS Process Startup: Fatal Error while opening NI-FBUS Communication Manager
Hello experts
I am using Windows Xp, I installed PCI-FBUS card, NI-FBUS COMM SW for Windows v 3.2.1 and activated all the licenses as well as allowed the PCI-FBUS board in Configuration Utility.
I received the following error message, when I opened NI-FBUS Communication Manager:
"NI-FBUS Process Startup: Fatal Error
Initialize request to Board 0 timed out, NI-FBUS may not be receiving interrupts from board. Check your board IRQ settings with the NI-FBUS interface configuration utility. NI-FBUS will not Exit."
But all the settings were in default. Just NI-FBUS Communication Manager will run successfully if an H1 interface board property is keep in "Polled Mode."
What should I do? Please help.
Thanks a lot.
