NiceLabel shows error when attempted to run the app
When I run NiceLabel I receive the following error message and NiceLabel does not start: “DLL file modified. Application closed!”What’s the problem?
DLL files that usually come with the program don’t get modified on normal usage unless it got expired and you tried to manipulate it to make it work again then this is the possible result. When a program expired and you purchased a license for it, what usually happens is that they will either send you the license combination via email or they will send you a program that you will use to register your version.
If the first scenario happens and they will send you your license combination, you only need to enter it to the program. Open the program and then register it. The Register function is usually found in the Help section. If the second scenario happens and they send you a program, you only need to run it to register your version.
If you previously updated your program, then maybe that’s the reason why a DLL file got modified. Uninstall the program then install it again. Click Start, Control Panel, Add or Remove Programs. Select NiceLabel from the list then hit Remove. Restart your computer and then run its installer again to install it back.
If this doesn’t help, download a different version from All Software Downloads.
