Nike Fuelbank vs Fitbit vs UP24
Which of these are better. Can i have a side by side comparison
What devices are compatible with which
What would the best buy be?
Here is the comparison of the respective specs of the fitness bands concerned:
Nike FuelBand SE |
Fitbit Force |
Up24 |
Colors are volt, pink, foil, crimson, black
Black and slate |
Onyx, mint green, blue, light grey, navy blue, red, orange and hunter green |
small at 5.79 in/ 147 mm, medium – large at 6.77 in/ 172 mm, and extra large at 7.76 in / 197 mm |
small at 5.5 – 6.9 in or 140 – 176 mm and large at 6.3 – 8.2 in or 161 – 209 mm |
small at 5.5 – 6 in or 14 – 15.5 cm, medium at 6 – 7 in or 15.5 – 18 cm, and large at 7 – 8 in or 18 – 20 cm |
Custom fitting links for a better fit |
Very light in weight which makes you forget you’re wearing it |
Real time progress visibility |
Environmental light sensor |
Comes with Nike+ FuelBand App |
Compatible with Mac and PCs, most explorer and mobile OS |
Comes with Jawbone Up App |
Water resistant |
Water resistant |
Water resistant |
Price is at $149 |
$129.95 |
$129.99 |
Includes activity tracking such as sleep, nap, drink, food and can schedule alarm to wake you up |
With motion sensors |
As far as the best buy is concerned, it depends. If you are the sporty type, then it is Nike FuelBand. If you are the simplistic type and you don't need anything fancy, you should go for Fitbit. If you are into function, then Up24 is for you.
Notifications
