I have a Nikon camera and have used the voice memo feature. On a number of photos pertaining to research work, I have done. Being new to iPhoto, I'm unable to find how to play back, or if iPhoto supports, the voice memo feature that is on my camera.
I would appreciate any help available.
Thank you!
Nikon camera Voice memo on photo
There is a method, where you are able to consolidate the sound record, for the remarks with the photograph to give you a QT motion picture document of the photograph with sound.
The sound records should be playable with Quicktime Player, for it to work efficiently and properly. You will need to manually unite the few outside of iPhoto with Quicktime Player 7. Infer to Apple-iPhoto men > give iPhoto input notwithstanding; check out your Nikon documentation to see how it is done to photograph programming and how to utilize it.
You will likely require their programming to utilize it and function properly.
