Nikon Capture NX2 crashes unexpectedly
Hi Pals,
I am wondering if anyone of you experienced an issue similar to the one I am about to explain. I am absolutely clueless as to what might me causing this issue. A few days back, I downloaded and installed the Nikon Capture NX2 version 2.2.0 on my Mac machine running OS X 10.8.4. I am using it in the 32 bit mode. This application just quits unexpectedly in the middle of something. I cannot pinpoint when this disappears, it gives an error message out of the blue and simply quits. The error message dialog gives me an option to re-launch it but clicking this option will not help. You will have to manually launch it again. But re-launching the software doesn’t solve the problem. It will crash again sooner or later. This is a really frustrating problem and wouldn’t let me complete any work peacefully. I tried uninstalling and reinstalling a couple of times. But I had to give it up as a useless method. Is this a bug? Does anyone know a fix for this? Please share. Thanks a lot for all the solutions offered.
Image:
Error:
The application NkMC quit unexpectedly.
Mac OSX and other applications are not affected.
Click Relaunch to launch the application again. Click report to see more details or send a error report to apple.
