Nimbuzz on sonyerics+B15756son w580 mobile
Hello
I have Sony Ericsson w580.
I installed latest version of Nimbuzz but unable to login into Nimbuzz?
Thanks
Hello
Thanks
Make sure you have fully functioning internet connection in your Sony Ericsson w580.
Insert your user name and password properly.
Then log in. If it fails again check forget password option to make sure you are not doing wrong with your password and ID.
Even though problem exists, downgrade to previous version in which it worked properly.
Every new updates usually has some bugs which are fixed afterwards by the developers.
Please confirm the following:
This would fix the issue.
Thanks and regards,
Skarbos Jay.
