Hi experts,
Can anyone tell me what to do with the controller synchronizing problem of Nintendo Wii U?
You know, even though the gamepad does not have a Wii-Remote style pointing sensor,
The Wii U ask you to point the gamepad at the TV. What to do?
Somebody please come up with a solution. It is very uncomfortable.
Nintendo’s Latest Wii U controller Synchronization Problem
Hello John! It seems like there are several issues arising from the Wii U’s controller. One of them is that if you use a second gamepad, the frame rate will drop down to 30 frames per second (most likely on the gamepad’s screen). There is also that issue of the battery life of the gamepads, looks like it only lasts for 3.5 – 5 hours and the recharge time (2.5 hours) is more or less half of the total battery life. The one that you are experiencing has also been a reported problem when playing the game “Ninja Star” wherein the Wii U wants you to point the gamepad at the TV even if it does not have the ir sensor of the previous Wii remote. There are reports that say that manual recalibration of the controller should resolve this problem
