Nitro Pro 7 conversion error
I have been using two PDF readers simultaneously, Adobe Reader and Nitro Pro 7.
Yesterday while using Nitro Pro 7 to convert an XLS file to PDF, I was met with a n error.
It was working perfectly before but now when I try to convert an xls file into PDF using Nitro, it says that it is already a PDF file and not an Xls file so it cannot be converted. I get the following error message:
Nitro Pro
There was a problem converting one of your source files
(C:UsersjbbakerAppDataLocalTemp4025-xxxxx-xxx-Rev#
Compliance Matrix.Pdf) to PDF. Nitro pro is unable to combine
the selected files.
                               OK
I also tried to convert Doc files to Pdf using Nitro, and it is working fine but not with the xls file. Why is that so? Recently I updated the adobe reader 10.1.3 so I thought that might be causing a problem so I uninstalled it and also reinstalled the Nitro PDF reader. Again the same error occurred.
Can anyone explain where am I making a mistake? Why is Nitro Pro 7 nut working properly?
Your suggestions are required to resolve the problem.
Regards
Bill
