Even if I have 64-bit Microsoft ACE driver installed on my PC I still can’t install make a connection to MS Access. I meet all the requirements and I expected that everything will work just fine. Can anyone explain me why is not working please ? What I did wrong ?
Thank you !
Create a database Connection
Connect to MS Access
Click on browse and select a Microsoft Access database. Then click on next to connect to the database.
No appropriate Access provider was found
No 64-bit Access driver could be found on your system. For more information about obtaining this driver, please follow the provided link:
points
No 64-bit Microsoft ACE driver is installed
MS Access is the greatest database management tool all over the world, in my opinion. Due to its super capabilities, many developers are using this product to increase their productivity. In order to work with MS Access, developers integrate some components that works with the MS Access driver to perform tasks with any Access database file.
In order to complete the task, you must have installed the 64-bit version of “Microsoft Access Database Engine 2010 Redistributable” package. Download Microsoft Access Database Engine 2010 Redistributable.
Download “AccessDatabaseEngine_x64.exe” and install it on your system. Restart your PC and work with the software. It won’t deceive your mind anymore.
