adam musick
20 points
Posted on - 08/16/2012
Hi all,
I find the following error picture when I try to startup Generic host process for win32 services.
Help me to find a solution.
Volume Control
There are no active mixer devices available. To install mixer devices, go to Control Panel, click Printers and Other
Hardware, and then click Add Hardware.
This program will now close.
 OK
No Active Mixer Device Available on starting Generic host process
Hello There Adam,
My suggestion is maybe you haven't assign a mixer that will play all the sounds on your computer. Try to go to control panel > sound,speech and audio devices >sound and audio devices. A window will appear, look for the audio tab and set the audio device default device. Click apply and ok.
Hope this will help you solve your problem
This error usually comes up when you have not installed an appropriate driver for your sound device. I would assume that you have a copy of the drivers included when you bought your PC, so try running it. If this still does not work, seek your local tech provider for support.
