Hi friends,
I wanted to take out 123D and do a clean install because there was an installation error the first time round.
When I try and uninstall it using the autodesk, there is no activity, I mean, it just does nothing. Is there a file specifically for uninstalling this program cleanly, which would take out all the registry files in order to do a clean install?
If I try and run the installer again, it shows that the product is already on my system.
I am running win 7×64. Screenshot of the error:
Autodesk 123D Installer
Could not open key:
UNKNOWN2225EE2FC2780DA409169A8AE99BDC609AF
6AEDE7B82CE84681C12BB761D9E9A. Verify that you have sufficient
access to that key, or contact your support personnel.
Please give me help.
Thank you people.
No activity while trying to re-install the program 123D
Hello Claire, You should try using the Max Uninstaller. It is a third party application that has been proved to be very effective solution when you need to uninstall Autodesk 123D as well as other stubborn Windows applications/programs/games. With it you can be sure ttha the target program you want to get rid of as well as all the related leftover will be removed totally from your computer.
If you are an average computer user, the it is highly recommended that you use the following instructions to save time:
1. First you will need to download the professional uninstall tool Max Uninstaller and the install it on your computer
2. Then you will launch it and then select Autodesk 123D in the program list that will be in the right hand side.
3. Click the "Run Analysis" button.
Be sure to click the Complete Uninstall” button to start the removal process as indicated in the diagram below:
After that look for the Scan Leftovers button and click on it, and then click "Delete Leftovers" so as to completely remove all the remains of Autodesk 123D.
Carl
