Jose81
Posted on - 10/20/2011
I am using Linux Mint LXDE 10 problem I am having is there is no audio. I have tried it in Live USB it worked great sound was great but when I finished the installation and rebooted it there was no sound. I have Acer Aspire 7741z-5731.
Johnnyd
No audio in Linux Mint LXDE 10.
Hi Jose81,
I'm sorry to hear that problem of . I'm hope you are doing okay now. May I ask what chip are you using? If you are using ICH7 like mine, I suggest you to follow my instructions below to be for your audio to work.
You need to change the file etc/modeprobe.d/alsa-base into etc/modeprobe.d/alsa-base.conf.
Don't forget in the end to add options snd-hda-intel index=0 model=Acer Aspire 7741z-5731Â Â Â Â
You need to change auto into Acer Aspire 7741z-5731 because obviously it is the brand of computer you're using. Keep in mind that need to reboot to be able for this to work out. I hope this might help you because mine really worked after trying this.
Johnnyd
