No call option for Skype programs in wave 2
I have downloaded skype programs in wave 2 and is working well, but don't have call option in it. What need to be done to make calls using skype in wave 2 ?
I can help you fix the issue with Skype on your Wave 2. I suggest you to check the following.
>>Make sure you have downloaded the correct compatible version of the Skype application onto your phone.
>>Please check if you have configured the Skype correctly on your phone.
>>Make sure you have the latest version of Skype installed on your phone.
>>If this does not fix the issue, try reinstalling the Skype application onto your Samsung Wave.
Thanks and regards,
Skarbos Jay.
Notifications
