harisson
1440 points
Posted on - 04/23/2011
i am trying to cancel an auto ship program involving a product. when i try to contact them at the email address i was given, i get this. "could not perform this operation because the default mail client is not properly installed. what does it mean? what do i do to correct it?
fritz
Default mail client is not installed
When you click on an email link, your web browser tries to open your default email program to send the email. This is usually Outlook Express unless you have configured another email program.
Go to Internet Explorer settings by clicking on tools and then internet options. Then go to the program tab and see if your email program is listed under the email section. If your email program isn't listed there, then this may be a bit more difficult to setup.
Depending on what email program you use will determine how hard it is to have Internet Explorer use it for its default email client. This may involve some registry editing which I don’t recommend unless you are an advance user.
harisson
1440 points
Thanks! You're great! If I know, your solutions are very good.
fritz
Ok. Just try it now for you to solve your problem. No problem. You're welcome.
harisson
1440 points
Thanks! Your solutions are very good! Nice to hear it.
