No disk drives shown in My Computer
Hello I am going to give you instructions for you to solve the problem that you are encountering,
It would be a simple instructions first is click on start, and then you should see my computer (you can also use my computer on your desktop) right click it and then left click manage.
And then a new windows will open find and left click the storage and then left click the disk management then you should see your hard drives or devices right click the device and then select add letters and path and a new windows will pop up then left click on add then the problem you is encountering is solved.
There are different ways of hiding and unhiding drive letters on the computer and they sometimes vary depending on the operating system you are using. I don’t have problems hiding and unhiding drives on my computer and I use partition software to do that. It’s less complicated since I only need to run the software and do a couple of clicks and that’s it, the selected drive is already hidden. But for those who do not have any partition software, there are different ways of doing these tasks. You can either go to the Local Group Policy or via the Windows Registry.
Hiding or unhiding drives through the Local Group Policy can be done using the Local Group Policy Editor. Depending on the operating system you are using, in Windows XP the editor can be launched by going to Start, Run, type “gpedit.msc” [without the double quotes] then hit Enter. Here’s what follows after that:
