anderson1
Posted on - 08/09/2011
I am fetching a big problem with my laptop.If it stays off for say ten hours,it works properly for less than thirty minutes when putn.After that if goes off and when i reboot it,it says there is no hard disk drive in the pc.Why is this problem happening?
No hard disk found on your computer
Most probably it due to the disc failure, you need not worry about that you wont delete any of the files saved in your HDD.It might have occurred due to any virus, it is recommended to run a virus scan on your hard disk to check any fatal errors.If the problem persist for longer duration it is recommended to change the Hard disk.
Your This Problem can Be Solved But Before This I want To Inform You That When This Problem Comes at Desktop or Tower PCs Then We Just remove The data Cables From The Hard Drives And Clean Out the Data Cable And Insert it Again Then This Error Wont Come again !
So Now You Should Remove The Hard Drive From Your Laptop. Clean its Jacks Then insert it Again !
