I have not used my PC in about three months. I went to log into it for a few files I needed and can not remember the password. There is only the admin password and no other users? How can I get into my computer without deleting everything on it?
No Idea What My PC Password Is?
If you forget the administrator password and if you don't have another administrator account, then you won't be able to reset the password. If there are no other user accounts on your PC, then you will not be able to log on to windows and you will need to re-install your windows.
To reset administrator password you will need to reset it through safe mode any time you forget your password. Follow the steps below to successfully reset your password. 1. Restart your computer 2. Press F8 repeatedly until advanced options menu appears. 3. Select safe mode and press enter 4. Login with administrator account until you see the login screen. Click start-control panel-user accounts and reset your password
