JoyLay
Posted on - 08/25/2011
I just ran the Windows 7 Ultimate CD on my computer. But after the installation is done, my screen is so large. There are no icons on my desktop, and the screen resolution is so bad.
Is there something else I need to install? Because when I purchased the genuine Windows 7 Ultimate CD from the shop, they told me that everything will be okay after I install it. But obviously, its not. I tried to connect my computer to the modem using my Ethernet cord, it does not even connect. It does not recognize my modem.
Please help!
Wallace
Problems after installing windows 7 Ultimate
Well these are common problems for all of us, mostly we don't want to face such kind of stupid problems. Well Windows 7 is installed properly on your computer and there is no need to change your Windows, just simply follow the steps and your problem will be resolved.
1) Right click on desktop in an empty place, a new window will appear where you will find so many options. Just click on view option, a new pop up Window will appear. There you will find three options of Large Icons, Medium Icons, and small Icons, just click on small or medium icons, your icons will be in the original position & size and you can easily use your Windows.
Hope this will work with you.
Pitter
This is Video driver issue. Normally Windows 7 installs video drivers automatically. Sometimes it cannot. So that time you need to install it manually. If you have the driver then please install it. If not then, collect it from your vendor.
Please follow below steps one by one:
Please install your Video card Driver. To resolve Screen and resolution issue.
Please contact with the Internet provider customer support department to re-connect your Internet.
Best wishes and thanks for contacting Techyv. If these suggestions help to solve your problem please reply back to us.
With thanks.
