No Modem Found Error in Nokia PC Suite
Asked By 220 points N/A Posted on -
I have a Nokia N97 with Nokia PC Suite that is included in the package.
When I try to connect my desktop PC to the internet with the use of Bluetooth on my Nokia N97, and clicked the Connect to the internet on the PC Suite, I received an error message stating: No modem found! Everything is working except for this. How can I fix this?
There are no Nokia modems installed. Please make sure you have
installed Nokia Connectivity Cable driver software.
No modem found
Answered By 0 points N/A #111313
Hello Kate,
Modem and PC connector cannot recognize on your system. Cause you would not create an account for connect on this profile. You just install the program and try to connect then. You need to connect on same profile media.
Go to tools setting and create your account. You must give your Ipv and dial up code. Which you will get from Nokia Zone or your friend who is used this modem.
Then give your area code and country code. After creating profile you can connect or dial on that user.
If do not get the help, you are clarify from control Panel and internet setting.
Regards.
your friend
