Hi experts,
This error occurs when I want to launch Aptana Portal with this “chinesse” error code (for me) which I cannot solve or read it. I have no idea what it means and what is causing it. All I know is that I have this kind of error for the first time. Can any expert help me please to fix it ? What I did wrong ?
Thank you !
‘Launching Aptana Portal…’ has encountered a problem. An internal error has occurred.
No more handlesNative coe library failed to load.
(java.lang.UnsatisfiedLinkError:/home/student/Downloads/Aptana_studio_3/plugins/
Com.aptana.swt.webkitbrowser.linux.x86_1.0.0.1345233987/os/linux/x86/libcefjni.so.62: cannot open shared object file:no such file or directory)
When installing Aptana Studio 3, make sure you meet all the requirements. For Linux, Aptana Studio 3.4.2 supports Linux Ubuntu 9+ and Fedora 12+. You should also make sure you have Java SE Development Kit or JDK because it is required. If you already installed it but you are not using the latest version, download Java SE Development Kit 8.
Once downloaded, uninstall your existing JDK and restart your computer. Install JDK 8 and then open Aptana Studio 3.4.2. It is possible that you have an outdated version of Java SE Development Kit that’s why it encountered an error. If you wish to download the installer again, visit Aptana Studio 3.4.2. Since the page defaults to the Windows download, click Customize Your Download to select a different operating system and then select Linux from the choices. See image.
For Microsoft Windows, Aptana Studio 3 supports Windows XP and up. For Mac, it supports Mac OS X 10.5 Leopard or higher and requires JRE 1.6 or higher.
