No more internet browsing while Mac Outlook 2011 is on Proxy settings.
I am on Exchange Server 2007 with 1 and 1 when I utilized Proxy settings on Mac Outlook 2011, it worked successfully. The problem was I cannot surf the internet.
What do I need to perform?
Answered By 0 points N/A #109357
Well, the proxy settings that you are using in the browser may be the ones causing you not to be able to surf the internet. You will need to go to the browser tools and check if you have configured them correctly. Maybe the browser does not require the proxy settings that you have configured for it to work, and in that case you will need to remove them and then save the changes. Try browsing after that and see what will happen.
Also, the settings that you just configured in the browser may not have taken effect yet and therefore you will need to restart the computer for the proxy settings that you have set to be effective.
-Lee Seen
