Hello Everyone I have a question. I am listening to my wmp on my desktop using my headset then I decided to try my Altec Lansing speaker unfortunately I heard no sound on it. The Speaker is ok I use it on my LCD. Tried checking the outputs and its inserted on the correct color. Any idea on where the problem is?
No output on my Speakers
Using the Control Panel and clicking the Sounds and Audio devices, you will make your solution. Go to the Audio tab. From the sound play back part, select the default service and introduce the computer with your Altec Lansing speaker device. It may stay under ‘Advanced’ button. If that, then press ‘Speaker’ tab. Select your speaker through ‘Speaker Setup’ button.
