No Print Screen key To Take A Screen Shot?
I have a HP 15 Touchsmart that I just realized does not come with a standard print screen key on the keyboard. It is a touch screen along with a built in keyboard. Is there a way touching the screen to capture a screen image or a multiple keys I can use to replace the missing key function?
Answered By 0 points N/A #191414
Usually, an external keyboard can give you a solution. Apart from this, you can download several software that enables you to do print screen. As an example, you can download 'Gadwin PrintScreen Professional' and use it to capture the screen shots. If you want to share the pictures or want to directly upload it to cloud, you can download 'My Print Screen' from Softonic.
