No Response From GameRanger Server
I have this error from GameRanger Server for two weeks. For the moment I thought that could be a problem from the server but now I don’t. It passed two weeks and I still can’t connect to the server. I have verified the official website and it seems like they never had a problem with servers recently. Does anyone have any idea why I cannot connect to the server ?
Thank you !
No Response FromGameRanger Server
There was no response after contacting the GameRanger server.
Click the Connect button to try again
Please make sure your Internet connection is working. You may need to check with your ISP or network administrator to make sure your Proxy Settings are connect.
If you still don’t have any luck, there may be temporary network problems somewhere on the Internet and you may have to try again a little later.
Connect
Exit
Proxies…
Best Answer by Sharath Reddy
Answered By 0 points N/A #175115
Hello There,
Please follow below steps
1.   Ensure your network connection is fine
2.   Ensure you can surf internet
3.   Check if gameranger web url can be pinged. Go to command prompt and run ping –t <the required url> –you need to press ctrl+C to cancel
4.   Now disable your all antivirus,malware protectors and firewalls
5.   Try now
Your problem should get resolved by now.
Answered By 590495 points N/A #175117
GameRanger is an online gaming service developed by GameRanger Technologies available as free version and paid version where the latter is subscription-based for Microsoft Windows and OS X. It lets you play multiplayer games online and offers different social features such as voice chats and chat rooms. It was created by Scott Kevill, an Australian developer and was first released in July 1999 for OS X.
In 2008, support for Microsoft Windows was added and it now supports more than 700 titles. Since you’re on GameRanger, this issue with the client showing the message No Response From GameRanger Server is quite common and appears very unusual. Sometimes it appears while the client is being installed.
There are times the problem just appears the next time you use it and even if your internet connection is working fine. Here is the workaround. Download GameRanger-Not-Responding-Fix.7z and unpack it using 7-Zip. Once unpacked, look for the folder called “GameRanger-Not-Responding-Fix” and rename it to without quotes “GameRanger”. Next, make sure GameRanger is not running.
Press Ctrl + Shift + Esc to bring up the “Windows Task Manager” then go to “Processes” tab. Now, look for “GameRanger” on the list. If you see it, kill it. Select “GameRanger” then click “End Process” and then select “End process” to confirm. After this, right-click the GameRanger folder you just renamed and select “Copy.”
Next, navigate to one of the following locations whichever is available:
  • C:\Documents and Settings\[your-username]\Application Data\Roaming
  • C:\Users\[your-username]\AppData\Roaming
These folders are hidden by default. If you can’t see them, in Windows Explorer, click “Tools” then “Folder options.” Go to “View” tab then under “Hidden files and folders” section, select “Show hidden files, folders, and drives” then click “OK” all throughout. Now, press Ctrl + V to paste or begin copying the folder.
When you are prompted to overwrite files, click to select overwrite all. When you are finished, see if GameRanger runs without error.
