Patrick Hay
200 points
Posted on - 06/27/2011
Hi Everyone,
I got a problem with my CD/DVD drive. Whenever I try to eject the drive using the options, I am getting an error stating:
"no scsi adaptor found".
Really, I do not know what this means. If someone can help me, my computer is running on Windows XP.
 I will really appreciate, if this can be resolved soon.
AlexT
No scsi adaptor found when using CD/DVD drive
This type of error just doesn’t recognize your CD/DVD drive. When you are using Just! Burn or other Burning Device this error appears. Upgrading Operating System or Operating System compatibility with your computer is the problem. You just need to UPGRADE the latest driver for your device.
Are you using Compaq Presario? Because this error is common to Compaq Presario. Here is the link to if you are using Windows XP:
Then remove your old version or CD recording program and use this one compatible to Windows XP:
http://www.roxio.com
shenna22
5 points
hi i read the issue about your CD/Dvd will not read. if there is no CD/DvD driver activity for two minutes or more, it may be that Autorun is not enable on the computer.
to run the documentation CD/DVD if it does not run automatically.Â
click start menu>>run
type X:DocLib.exe   ( where X is the drive letter designator for the CD-room drive)
click OK.
    i hope you can do it….thank you…
regards;
shenna22
