No sound from speakers??? What to do?
I am using Micro lab speaker.
Till yesterday, they are perfectly fine.
But, from today morning I didn't get any sound from my speakers.
Please help me.
Please help me.
Please, check the back of your computer and see if all the connectors are properly connected.
The speaker plug should be put into the socket on the sound card that has a mark Audio Out.
Hope this will help.
Do the solutions below:
Solution 1:
Check all of this necessary things, connectors if plugged in the green socket, the power of the speaker.
You can also try testing it to other device that has audio in your house and see if it is working.
Solution 2:
Still no output then, reinstall your sound driver in your computer. Use the CD provided with your motherboard or download it in the internet. Or you can try uninstalling it using the Device Manager options.
Solution 3:
If still no sound is coming out, then your built in sound card is broken so you just need to buy a new sound card and plug it in your PCI slot in your motherboard.
There seems to be a problem with your speakers.
Ensure that they are properly connected to the power outlet and that the audio cables are connected properly to your computer.
If this doesn't work, try to connect your speakers with another computer to check if there is a problem with the speakers themselves.
Hi
Check out this Techyv link to get more helpful tricks to fix this issue.
