No Suitable Text/Html Decoder Plug In Error
Whenever I try listening to Internet Radio or any Music from a web browser in Ubuntu Lucid, an error message appears:Â
Couldn't find a suitable text/html decoder plug in.
I have attached the error I am encountering every time I try to listen or stream online.
Error:
Search for suitable plugin?
The required software to play this file is not installed.
You need to install suitable plugins to play media files.
Do you want to search for a plugin that supports the selected file?
The search will also include software which is not officially supported.
Please help.
