Hi expert,
I am using an iPod. To chat with my friends and I am using the chat room. But there is no topic showed in the chat room. Is there any option to switch on it. If there are any such apps which included above mentioned function please give me the free download link on that.
No topic showed in ipod chatroom
To view chat room contents on the iPhone you should follow these following steps:
1. Go to the window of the chat room and select rooms which will display chat room list window.
2. Give your desired keyword (The room you want to visit) in the search bar.
3. Press go button which will display the list of the chat rooms that match to your keyword.
4. Click the name of your desired chat room.
You can download Yahoo Messenger which is designed both for the iPhone and iPad.
My advice for you is to try to download a good iPod touch chat application which displays the topic in the chat room, there are various applications which can do that, if you go to the apple store, in the social category, you will get the various applications.
Also you can try Skype to messenger, aim and face time.
Thank you
