joan d vogt
10 points
Posted on - 01/03/2013
Dear TechyV Readers, I am here with a critical problem. A few days ago, I got the ‘Patch for Yuri's Revenge v.1.001’ downloaded into my computer. Later I attempted installing that. In the very opening it informs me of ''Invalid REGISTRY/INI" or something similar to that.
I am not sure about it. Later I fixed it up by means of some other arbitrary registry files which were in the stuff. I also got them downloaded. At that time I met another error message which says,
Patch 1.001 Error
Old File not found. However, a file of the same name was found. No update done since file contents do not match.
Can you tell me how I can fix it up, please?
Hi Joan D Vogt,
The reason for the error is because you are not using the original exe of the game. You need to restore the original exe and then it will be fine.
Hope it helps.
Hellow Jaon D Vogt
I have realized the problem you have faced. It might be occurred due to several reasons.
The patching software might be expired.
The patching might not be installed in a right way.
The file directory is invalid
The file to be patched might be corrupted.
The file you have choose might be patched by another software.
Please follow the instructions
Reinstall the application first correctly.
Reinstall the patching application.
Read the manual carefully
Then proceed the patching.
Enjoy the full version of the application.
Regards
Shifflett Laurel
The best solution for this error is to uninstall the game then install it again. It happened also to me and I had to re-install it just to work. Then it works. You have to make sure that the old installation folder deleted before to install it again. Normally the name of the folder in program installation is the name of the game, so just delete that folder which is located in C:Program FilesGame Folder Name. Don’t worry if you think that you will loose your saved game. They will not be deleted because the saved games are stored MyDocuments/Game folder.
