joey keen
190 points
Posted on - 12/02/2012
Hi Friends,
I have a problem in ATIWinflash while flashing bios using ATIFlash, No valid Adapter could be found! Video BIOS not updated!
Any solution for this error?
Thanks for all solutions.
ATIWinflash
ATI WinFlash software is one of the best software’s out there. Your problem indicates that there is no motherboard video graphics driver installed. So you have to check if the video graphics software has been installed. If it is not installed, reboot your computer. And then run WinFlash software. It is highly recommended that you use the latest version and update it regularly.
There is another software ‘TechPower’.
It is very easy to use.
