NOD32 won’t work as my external scanner in hMail! Help
I recently installed hmailserver (works great) and I installed the new version of NOD32 ( 3.0.621). I tried to setup nod32 as external scanner, but with no success.
Here is the command line I use:
"C:Program FilesESETESET NOD32 Antivirusecls.exe" –files –no-boots –arch –mail –sfx –rtp –adware –unsafe –unwanted –pattern –heur –adv-heur –action=clean –no-quarantine –log-file=C:tmplogNOD32.log –log-all "%FILE%"
The file is not scanned ( I get a return value of 100) and in the NOD32 log it says:
ECLS Command-line scanner, version 3.0.621.0, (C) 2007 ESET, spol. s r.o.
Scanner initialization failed.
"ERROR" 2996 "2008-01-23 10:13:57.121" "Source: ADOConnection::Execute(), Code: HM10044, Description: Error while executing SQL statement:
update hm_settings set settingstring = '"C:Program FilesESETESET NOD32 Antivirusecls.exe" –base-dir=C:Program FileshMailServerTemp –files –no-boots –arch –mail –sfx –rtp –adware –unsafe –unwanted –pattern –heur –adv-heur –action=clean –no-quarantine –log-file=C:tmplogNOD32.log –log-all "%FILE%"' where settingname = 'customvirusscannerexecutable'
Microsoft OLE DB Provider for SQL Server
String or binary data would be truncated."
