Nokia 303 can’t connect to pc with pc suit
Make sure you have the latest version of Nokia PC Suite by clicking here
If you are asked to Run or Save the File, click Run. This will start the installation.
Accept the security warning (if any)
Make sure you have the latest driver installed.
Once the installation has complete, connect your phone to the PC via the USB cable. You can also use Bluetooth, but clicking on the “Use Bluetooth instead” button.
If you have a Nokia account, sign in. If not, you can create a new Nokia account.Â
How to use a Nokia 303 as an Internet Modem
Double click on Nokia PC Suite program.
Connect your phone to your pc via the USB cable or a data cable.
Go to Menu > Connectivity > Connect the PC to the Internet
The phone will now sync with the pc to connect it to the internet
Click Connect to the Internet
If you want to share the internet connection on your phone with your computer, you can try Joikuspot. If you’re using an Android or iOS device, sharing your phone’s internet connection would be as easy as creating a Wi-Fi hotspot without installing any app transforming your device into a Wi-Fi router that your laptop can connect to.
But since you are using a Nokia phone, your best option is Joikuspot. It is a Wi-Fi tethering mobile app for S60 Symbian phones like Nokia. The app transforms your Wi-Fi-enabled 3G phone into a Wi-Fi hotspot so you can connect your laptop, iPhone, iPad, and other Wi-Fi devices and access the internet using your 3G connection. There are two versions of the app: Joikuspot Premium and Joikuspot Light.
Unfortunately at the moment, the Joiku website is inaccessible. This means you cannot download and use the Premium version. The remaining option you can try is the free version, Joikuspot Light. Try downloading Joikuspot Light for Mobile.
