Nokia 5130 internal memory problem
Asked By 7060 points N/A Posted on -
The Nokia 5130 xpress music it show me that the memory is full but i stored all my data in memory card before my phone memory is 29 MB now it show me 3 Mb.
Please i check all my phone folders all of them are empty and how can i get it again help me.
Best Answer by Michelle Bang
Answered By 55 points N/A #82164
This is a very common thing that the phone memory is being eaten up. The main reason behind this is that the mobile phone keeps a cache memory stored all the time. So whatever you do with your phones goes in that cache and it can never be erased. Also that cache folder is not visible for a normal file manager. Following are few steps that can help you regain your lost space,
  • Download OXYCUBE. It’s a files browser for mobile phones. This software allows you to access those folders which you can’t browse and access from any software.
  • Install it.
  • Attach the phone via cable using pc suite option in the phone with the PC.
  • Connect phone with OXYCUBE software on the PC.
  • Browse through the phone, go to Hidden folders, and go to Themes active, here you can see all the themes you have applied since you bought the set.
  • Even though you have formatted it many times but the themes never go away from the cache as i said. So delete all those themes and then see the difference.
  • After that you can apply the themes on your phone just like before.
  • Regularly clean it using OXY CUBE software and stay HAPPY. I bet this will solve 99% of the memory problems for Nokia 5130.
