Nokia 5130 xpress music won’t open
I tried to update my Nokia 5130 xpress music but there was a problem with pc suite and it shut down and after that my phone wont switch on
This problem may be caused by the PC in charge of the update process loosing contact with the Nokia device. Due to this, the phone display is suspended. You need to follow the following steps:
IT seems that there might have a problem has occurred in your Nokia 5130 xpress device software or one or more files may be corrupted. So you have to install new software. New software will not only help your Nokia device to be turned on but also will help to run xpress music too.
For your better I am requesting you to take your device to Nokia customer service center. But you can try on your own risk. To do so,please connect your Nokia 5130 xpress device with your computer by data cable. Then delete the files unnecessary. Keep out memory card from the phone. Then using Nokia PC suite download a new update of your Nokia 5130 xpress software and install it.
Have a good luck man.
