anonymous
7060 points
Posted on - 08/03/2012
I have my all data in my memory card, i left nothing in my phone memory like messages,contacts but in past i installed many themes in my phone so they occupy my phone memory then i got instructions from your site and used oxycube thanks to oxycube
IÂ have recovered 10 mb more data by deleting many hidden themes in phone memory but some themes i can't delete coz they are read only files and then taken my phone memory space ''how i delete those read only hidden themes from my phone memory.''
Nokia 5130 xpressmusic low phone memory
Ok don't worry about it there are many mobile softwares now available in mobile9, you have to delete the read only files from your mobile I also faced once such type of problem just follow the rules
Step1: Configure the internet setting on your phone and go to your browser and visit mobile9.com
Step2: you can find there search option type read only file remover when it appear then download it and remove them.
Step3: register a free account and login after download install it in your phone and then go to the menu and then remove read only files and the url is
mobile9.com
thanks
Hello dear,
You remove the file from your computer. Please follow my instructions.
1.Install PC suit in your computer
2.Connect the phone to your computer
3.Click on the start menu and then go to the control panel
4.Now click on the folder option menu
5.Go to the view tab
6.There is a radio button named Show hidden files, folders and drives. Check it ok
7.Below that, uncheck the option named hide protected operating file system
8.Apply the setting and press ok
9.Now go to the phone memory from my computer
10.Select and delete the files unnecessary
Thanks for your time
