Nokia 515 Phone whats the cost of this phone
Nokia 515 Phone does it have an FM, What's the max memory we can use on this phone?
Any relevant info could be useful
Hi Postii,
The Nokia 515 phone costs $149.
The specifications of Nokia 515 are:
1) The phone consists of FM installed in it
2) The max memory size is 64 MB. It is expandable up to 32 GB using MicroSD card
3) It consists of 5 MP camera with 3 x digital zoom
4) Nokia Xpress Browser is used for internet browsing
5) It provides GPS and navigation
6) It supports Java applications
7) It has 2.4 inch display
8) Face recognition, full screen viewfinder are provided by the camera
For more specifications you can visit the official Nokia website
Hello
The Nokia 515 phone costs $150
I have answers to your solution, as listed below.
Yes, it has stereo FM RDS with FM recording.
It has 64 MB RAM, 256 MB ROM+microSD card (supports up to 32 GB)
This information is related to your question.
You will fine answer or solution to your problem. This is the main answer to your problem that is discussed above.
