Hi There!
I need a special help for my Nokia 6300 cell phone. I use many colourful themes on my phone. All themes are look like very pretty and beautiful. But I cannot edit any theme. Yes. You are right! I mean that you understand my question?
I need a good theme editor for my Nokia 6300.
I want to use it my phone or personal PC.
It is must be freeware and no trial
Thomson
Nokia 6300 theme editing application
You can find many theme creators for your phone. They are divided in many categories. They will work different sides of themes. So you need to use more then one software for edit your themes.
1. Mobiano themes box 2.1 . This is great software for editing themes. It will change the look of your mobile time to time.
2. Theme maker x 3.6.1. It is the best theme creator for mobile. It will helpful to change color and icons of the theme. Also can change progress logo.
3. Theme gen ce 2.6. It will help to modify your themes.
These software you may use for edit your phone’s theme.
