Nokia 888 is a new phone that can be tied to your wrist. It is a touch screen phone with voice recognition and other amazing application. With this kind of amazing technology will it survive the intense combating of different cell phone provider?
What operating system does this new phone used is it Android or Windows?
Nokia 888 A Paper Like Phone
Yes it will very survive the extraordinary combating of various cellular phone supplier as a result of the Nokia 888 is that the future generation from Nokia that build our life to be additional compact. Tamer Nakisci press on analysis regarding the mobile and he promise the Nokia company to introduce this as soon potential by Nokia developers. Nokia 888 phone is work into any a part of our body. It could be a paper like mobile simple for travel and use. The operating system of Nokia 888 is Android.
A personal mobile communication device that permits you to be free and fun. It's light-weight, straightforward and carefree. You'll modification is kind consistent with your desires throughout the day. You don't got to carry it in your pocket or on your wrist. You'll carry it anywhere, in any form.
You'll roll it, bend it, placed on your garments sort of a clip. It additionally makes some kind changes that creates it additional ergonomical: i.e. once you need to speak on the phone, the body kind turns into the shape of the great previous phone. you'll personalize these forms and record them. Thus it fits you the most effective within the manner that you just have chosen. additionally e-motions allow you to send forms to alternative 888 users: i.e. you'll send a heart form to your girlfriend or a dancing figure to your friends to decision them to the party tonight. this manner you'll speak while not words.
Tamer Nakisci explains intimately regarding this work.
*Technologies that are used
It uses liquid battery, speech recognition, versatile bit screen, bit sensitive body cowl that lets it perceive and befits the surroundings. It's an easy programmable body mechanism so it changes forms in numerous things.
*The functionality of style
You don't got to carry it in your pocket or on your wrist. You'll carry it anywhere, in any form. You'll roll it, bend it, placed on your garments sort of a clip. It additionally makes some kind changes that creates it additional ergonomically: i.e. once you need to speak on the phone, the body kind turns into the shape of the great previous phone. You'll personalize these forms and record them. Thus it fits you the most effective within the manner that you just have chosen. The functions that it's additionally produce a sense of electronically pet, because it senses your moves, perceive what you would like, respond you within the best manner. It learns you, to suit you higher. Also e-motions permits you to send forms to the opposite 888 users. It can be the form of a heart or a tiny low dance. This manner you'll speak while not words.
*How the user interacts
E-motions… It suggests that electronically motions that 888 has. you'll send and receive forms from / to friends. You'll send a heart form to your girlfriend, thus her phone turns into an icon of heart. otherwise you will send a dancing kind to your friends to decision them to the party tonight. this is often the fun aspect of the merchandise. If we glance from the functionality aspect, 888 is kind of versatile. You'll place it into your pocket, roll it and build it smaller, or placed on your wrist once you need to create a video decision on the go. If you would like to speak sort of a traditional phone, there you've got your phone form. we tend to undergo plenty of places and things within the existence, thus it appears like one kind isn't enough.
*What is exclusive
You can modification the shape of the body. Not simply the color. And you'll do constant by sending an e-motion to your friend.
*The inspiration
The idea is that “the excellent form” doesn't exist. “Form follows you” we tend to produce the right kind for every perform.
Nokia 888 is the futuristic design of Nokia Mobile phones. Designed by industrial designer Tamer Nakisci in 2005, this ultra-slim bendable mobile phone which is only about 5 mm thick will be a hit in the market.. Yes, this amazing technology will conquer the world of youngsters and tech savvy people in the future.
Top of the line phones nowadays also shares the same feature with Nokia 888 according to the specs released, so as of now its edge when compared to this phones will be its unremarkable touch screen technology and its very unique design. However,when it comes to phone wars, other cell phone providers also do their homework.
They have their own version of futuristic bendable mobile phones which is even more colorful and unique than Nokia design, so when the time comes that this technology is available, for sure there will be a lot to chose from, but of course Nokia is one of a kind when it comes to quality and versatility of features. As to the OS, majority of phones nowadays uses Android Technology however there are no announcements yet as to the OS this design will run.
