Is the Nokia Contacts Editor included in the Nokia PC Suite?
Does the Nokia PC Suite include the Nokia Contacts Editor? Is it compatible with all Nokia Phones? Can you add, edit, import and export contacts using the Nokia Contacts Editor?
Hello! Good Day!
Yes, Nokia PC Suite has a contacts editor. Once your phone is connected to your Computer, you can sync your contacts from your Cell Phone to PC or from PC to Cell Phone. It is compatible for most of the Nokia Phones.
You can download the latest Nokia PC Suite here:
Hello Perezlee,
It is amazing how the Nokia PC Suite can be able to do much more on your phone. The answer to your question is Yes!
You can even delete multiple contacts in your phone using the Nokia PC Suite.
For a list of compatible phones that can be connected using the Nokia PC Suite, please check the Nokia website.
